- Glenmoore pa
Hey All,
I've become mildly obsessed with ignition control recently... I've always hated MSD TL as its antiquated and unreliable. Zeel is fantastic and I've used it on all my setups so far. Every back-to-back test so far has shown almost no performance difference but recent testing on my TPE 12 showed enough bottom end gain to make it worthwhile (It wants to be over-rich down low and zeel can't burn the extra fuel).
So, I've toyed with loads of alternatives to MSD but the one I like the most is:
Things I'd Like to Try:
- I still don't know what pickup type the MSD pickups are. They aren't reed switches and they aren't hall effect sensors. If anyone has the term for what type of pickup they are, that would be helpful as I'd love to see if i can make this work with MSD stock pickups
-Possibly look at RusEFI as an alternative ECU
I'm mostly dropping this thread here so I feel the pressure to actually do something with this idea hahah. Open to any thoughts/suggestions.
-Jordan
- Speeduino open source ECU. Based around an arduino, so it's cheap. Can handle up to 4 cylinders and lots of trigger types. Can fire smart coils. No built in standard coil drivers.
- Use mini hall effect sensor (55100 type sensors) and a trigger wheel somewhere - either rear mounted or a wheel sandwhiched between flywheel bolt and flywheel
- Use "smart coils" - smart coils are used in many applications and they have the coil driver built in. For example, MSD makes an LS1 engine coild. They take their own +- 12v wire and a low voltage (TTL) signal from the ECU, so the spark energy is determined by the driver in the coil. I'm sure there's some smart coild out there than can output a similar spark energy to the MSD TL
-Jordan
