- Clearwater, FL
Are the hulls the same on a 650 SN and a 701 SN?
I don't think the 90-93 and 94-95 midshafts are interchangable otherwise they are the same
are the driveshafts interchangeable between the twoBingo.
90-93 SN uses the old style small midshaft housing and the thread patterns on the shaft are different from the new style shaft.
94+ uses the newer, larger midshaft housing and shaft.
However, the housing off of a 90-93 SN uses the same bearings and can be updated to the newer shaft.
