SN pole bracket, RN pole, what spring?
I've got spring from an '08 SJ but it doesn't appear to work with the sn bracket. Am I doing it wrong or do I need to use a SN style spring?
hhh
i use a blowsion RN spring with my SN bracket. i had to drill a hole in the bracket to allow the spring to patrude down. i really like this setup, its nice and light
FyrHazard
Ski Eat Sleep Repeat
Iowa
you guys got any pics of that done? I've got a blowsion RN Spring sitting here. Do you need to wrap the pole end clear around so it's opposite the base end? Can't seem to find any pics of rn springs installed.
hhh
i just drilled a hole in the bracket and ski to hold the rn spring in place. do some trial fits and find out where it needs to be.
good luck
I went with rn bracket and pole but before that I saw a pic of one that used a big spring that came out of the bracket area and pushes on the out side of the pole. I think it's a spring from a '94-'95? Can anyone verify?
