SN SJ Factory foam fill holes...where???
SXIPro
JM781 Big Bore
My 1992 SN currently weighs about as much as my RN and FX1 combined (slight exaggeration but it is back breaking to lift/move this pig around now). Anyone have pics of where the factory foam fill holes are? I believe one of them should down around where the steering cable comes thru the bulkhead, but for the life of me I can't find it. Anyone have pics? I can't find the white 'stickers' Yamaha used to cover them. The whole area is nice and flat, and if I had closed it/them off when I refoamed, I must have done a perfect job, which I highly doubt because I am a hack with stuff like that.
Here’s where they are on a round nose. Not sure if it’s different on a sn. I already filled them but you can see on the left / right about 1/3 way up the bulkhead.
SXIPro
JM781 Big Bore
I still can't find them. Maybe I did a superb job covering/filling them. That build is a blur to me. Too long ago and I know there were a LOT of Sam Adams Octoberfest involved. Thanks for all the help guys!!
SXIPro
JM781 Big Bore
Do you have a drain plug on it? hook up some air at 2-3psi and see where it is leaking.
I'm gonna put a couple in for sure. Because if I have to tear this apart I'll be going the hard pink Owens Corning crap from HD, so I'll need drains anyhow. I'll try that! And I may even try a shop vac for poops and giggles.
