Ok so just finished up my rocketed and shortened superjet install a blowsion griddle head 180 in each hole and wetjet pipe and the pump side I used my old wear ring and prop 9-15 solas and installed a solas mag pump and blowsion trim nozzle my problem now is any time I hit of 1/4 throttle hit will just hit limiter and cavitates really bad thought it was in limp mode for a minute that wasn’t it installed new pump seal and sealed everything really good same issue no change never did it before so it’s hard to believe it would be caused by the prop or wear ring
