Is the HSI bracket the only conversion bracket that has a pole lock integrated into it? I would rather not run a tight pole, not sure if people are modifying hazard brackets to have a lock, or the Watcon one, sort of unclear.
If you have an old hazard or watcon you can drill a hole (some it’s already there) on the side and run a bolt/nut with a spring and push it sideways when pole is up. Other ideas have been presented on PWC today. look in individual builds and all the squares
