Super Jet So much for a quick foot hold install
That warm fuzzy feeling you get when you cut into the tray and get hit in the face by water
WV
So how would someone fix that cooling tube? Cut it off, put in a new tube, and use some 5200 around it? I'm new to skis, so forgive my ignorance.
The tube is fine, just the sealer around the tube in the pump tunnel is cracked. I’ll just clean it up and reseal but I had to remove ALL the soaked foam.
