And, how do i correct this?
Theres alot of space,the mounts are in the right place and the plate is slid all the way back.
Does the midshaft slide or something?
if yami you can press the midhaft forward while making sure you still have enough spline engagement on the pump shaft.service manual has required info.
on kawi maybe pushing the pump as far as it'll go.
some will add washers behind the couplers for both brands.
