Solas 148 pump
Surprice that would work. 155 uses a different pump seal. Wouldn't think the bolts would line up.
They make the skat 148 wear ring by machining the 144 housing to match a 144 stator housing bored for a 148 mag stator your right. I believe once I saw a 148 made inside matching 155 housings with some type of filler to close the gap all the way around; that pump was for sale here.
Has anyone measured the inside of a wsm housing without the delrin insert?
Yup tried this a while ago. Too big with out the liner. Liner gets too thin when machined for the 148. I did make it work but I had to epoxy the liner to the housing then machine the liner on the lathe to 148mm. Epoxy helped the very thin liner hold its integrity long enough for a few rides, but time it took to do all this out weighed the cost of the very nice Solas ss wear ring.
