New Solas MAG pump 144mm 12Vane SS for Yamaha
JetManiac
Stoked
Vendor Account
orlando
Solas 144mm MAG pump for Yamaha
These are the all stainless steel 12 Vane lower cost 'MAG' pumps that many have been talking about, JM earlier review here:
http://www.x-h2o.com/index.php?threads/solas-ss-mag-nonsetback-144mm-pump-review.103667/
These pumps directly replace your stock pump vane section. They are non-setback so they use your same stock driveshaft and will fit directly into your superjet -SN or RN including '08-'12, or Waveblaster.
You use the same wear ring and reduction nozzle from your oem pump.
These are big hub pumps so you want a big hub impeller made by Skat-Trak, Impros hooker, or Solas.
- Solas 144mm 12Vane nonsetback SS MAG pump for Yamaha $539. Sale 399.
Medium pump cone and SS allen hardware included
- OEM bearing and seal kit $119.90 sale 98.80
- Freestyle short pump cone for the Solas pump 58.90
Pump builds
JetManiac is also offering Solas pump builds with bearings, seals, driveshaft greased and installed -ready to install
Solas 144mm 12Vane nonsetback SS MAG pump for Yamaha 469.
Oring for reduction nozzle impeller washer/spacer included
OEM pump bearing and seal kit $99.90 sale 81.90
Driveshaft for SJ, '08-'12 SJ, or WB1 with clean oem splines 189.
Installation/pump build
Total Solas MAG pump
+add Impros hooker impeller installed option available
Solas 148mm MAG pumps
Solas 148mm 12vane SS Pump stator $650. Sale $549.
(Includes solas pump cone and ss hardware)
Solas 148mm SS wear ring $400. Sale $359.
