hull with pole. gen 3 Bob with a kavinchi pole, all cable levers included 4500.00 complete for 8500.00 has dasa 905 89.5 bore 72mm stroke blackjack 44mm carbs factory b pipe 144 pump with thrust trim and 9/15 skat or can sell with a 701 with bpipe for 6500.00 hull has normal stress crack and a couple bigger chips you can see in the pictures overall 7 out of 10 if you want to flip this ski is for you
