- Palm coast
$9000obo part out the whole ski only if the hull sells first
2017 rickter xfs competition
(this was previously Godzilla built by aquaholic)
This whole build minus the hull has 4 hours on it. I built the ski in March of 2019 with the best of intentions however life gets in the way and I’ve only put 4 hours on all year. I just can’t justify having this much money tied up in a ski that I simply do not have time to use. There was absolutely no expense spared on this build ! Here is the list, I will try to remember everything!!
2017 xfs competition weighed in at 60lbs with with turf,foot holds,pole bracket,etc the hull I would say is a 9 out of 10 in condition.
Rrp Carbon intake grate
Rrp carbon ride plate
Dasa 1100
Hiro ninja 48mm carbs and prok filters
Dasa intake with v force 3 reeds
Rrp carbon lay down with rrp water box
Stock charging ignition with jetnetics flywheel and msd enhancer.
Cold fusion builit midshaft and housing.
Thrust 155 setback 2 piece 14 vain pump with thrust trim and carbon rrp flo guard.
7-16 cutback skattrack impeller
Rrp lightweight pole with rrp steering and bars,text tream ninja chin pad.
Jazz 2 gallon tank with prp fill.
Blowsion heavy duty steering cable with heavy duty ends.
Jet maniac heavy duty throttle cable
Jet maniac carb brace.
Jet maniac flywheel cover
Highspeed industry’s cold water manifold.
Rrp hull hooks
Ada pissers
Thrust finger throttle
Titanium hardware
the list goes on and on I have probably forgotten a couple of things.
Buyer will not be disappointed in this ski tuned to perfection will idle flip all day long !
This ski looks like new there are a couple of small scratches on the underside of the
hull but nothing bad at all !!
The ski is titled here in Florida!
Serious buys only no time wasters no trades!!
$24000obo
I will help assist with shipping not a problem.
Text 386-264-5508 for prices
Dasa 1100
Rrp hull hooks
Ada pissers
Titanium hardware
$24000obo
