Space Shuttle Launch - cancelled
Status
Not open for further replies.
Y
yamaslut
Guest
for those who do not know, THE SPACE SHUTTLE has been pushed back to Jan. 10th and if you have not seen it go up. it's awesome and will give ya goosebumps everytime...
:bananalama:
Y
yamaslut
Guest
NIght launches are by far the best... but daytime is awesome too...
we are probably less than 80 miles from Kennedy Spqace center. Pray for no clouds
Y
yamaslut
Guest
scheduled date:
Date: Jan. 10 +
Mission: STS-122
Launch Vehicle: Space Shuttle Atlantis
Launch Site: Kennedy Space Center - Launch Pad 39A
Description: STS-122 will deliver the Columbus European Laboratory Module and will be the twenty-fourth mission to the International Space Station
the date is not marked as tenative or earliest date, it says target date. There is always a chance of it being later on due to problems...
parrdaddy
No he will not!
The date is pending on testing being performed today on the ET. There will be a press confrence this afternoon to discuss the prelim test results, if things go well and we find the problem the 10th should be good. If we still can't pinpoint the issue and fix it......who knows when it will go?
BTW, the 10th is Thursday. If it ends up going up on the 11th I will most likely not be at the freestyle clinic (Sorry Slutty, I told you otherwise a few days ago, it looks like I will need to hang around for the launch).
Here's a picture for fun, I took this back in June before STS-118. I got to ride on the Crawler from the VAB to pad 39A with Endeavour :bananalama: This shot was taken after we delivered the MLP and Shuttle, and were backing the Crawler back down to the base of the pad....it is one of the coolest sights I have ever seen :wavey:
Emm
skank
Huntsville, AL
Kick a** pic!!!!!!
Y
yamaslut
Guest
scheduled for 2:30 in the morn wed....
THAT IS SOOOOO FREAKING COOL!!!!!!!!!!!!!!
Emm
skank
Huntsville, AL
yeah...strange time huh? I REALLY hope it goes off that day!
I know I will be up! and we will be moved then...MUCH better view :headbang::headbang::headbang:
Status
