SXR spare line
does anyone know where this line goes or what it is for. im talking about the pipe with no hose on it,just below the right mounting bolt
i think anyone that has defoamed there ski might know.
Idaho
That open line is the overboard fitting that dumps to the pump area and not the side of the ski. On a stock boat, the pisser from the head connects to this in the bilge area by the battery
Idaho
My bad its a kawi not yamaha
Not be that guy but im still unclear. i replaced all the hose under the hood and in my ski and there are only two hoses coming out of the bulkhead. one is the cooling line and the other is the bilge line.
TimotaLT
Lake Rat
Lake Travis, TX
There is 3 stock, the top one looking at the back like your pic is an overboard, the middle one is from the pump (cooling line) and the bottom one is the stock bilge that is hooked up coming from the reduction nozzle
TimotaLT
Lake Rat
Lake Travis, TX
They're all 3 there for sure but can't remember where that line is but it's on the bulkhead, it should be connected from the pipe or head. I took mine out and used it for dual cooling when I defoamed or I would go look
Idaho
It is the line that has my trim cable going into it (has yellow sticker on it) Should be just next to the battery. The stock siphon is behind the battery. Cooling line crosses internal of the tray and comes in by the exhaust mani.
I found it. Funny. Thought I replaced all the lines. So...its an extra pisser? Wonder why they didn't just run it over the side our tee into the existing line
