- Santa Maria, CA
So recently I have been going thru plugs quite a bit. I think a set of plugs should last longer than 15 gallons of fuel bring run thru the ski. Recently I have been putting the ski in for the first ride of the weekend and I crank and crank and it doesnt go. Pull the plugs and find some deposits build up causing the plug to sort of ground to it self instead of jumping the electrode gap. I can actually see this happening because when I crank the ski over and have a plug pulled touching the electode to ground it wont spark. If I make a good 20 to 30 thousands gap between the electrode and a grounding point the spark will jump from the electrode to the grounding point. Recently I have been cleaning the plugs real good removing these deposits and it will run fine all weekend. My question is, is what is causing these deposits?
ty oil? low compression? the fact that I do suck in some water from time to time? too rich? I have yet to do a good diag on the plugs to see what color they are after being ridden. I have to bring some tools to a launch ramp to do it since I set the ski in with a davit and I dont like pulling the hood while the ski is floating. Also have to test compression. Im running that pennzoil stuff you can buy a wal mart, premium fuel, 92 or 93 octane. stock 650 SN. Seems to run good but I have very little to compare it to except 550's. Never ridden other SJ's.
