Freestyle Spinning Impeller or Cavitation
IS0LD0UT
I hate winter
MN
How do you tell the difference between a impeller that is pitched too low and a leak causing cavitation.
I was running a 13/18 Hooker, Skat Mag combo with my 5mil. I was ok, I thought it was maybe overproped a bit. I ordered a hooker 11/17 and installed it, not my first time installing a prop by the way.
The engine revs fast in water and I cannot get up to speed and sounds a bit funny. I think its slipping but I have not felt what that is like before so I am not sure.
Schmidty721
someone turf my rails
WI
I'm curious as well. I'm running a 10/16 in a stock pump and want to try a 9/15 but am afraid I may "spin" the prop.
IS0LD0UT
I hate winter
MN
I think I am going to try to repitch it to 12/17 and see how it goes.
Wil changing to a shorter cone make it a difference when its slipping? Or is that just a really fine tune?
IS0LD0UT
I hate winter
MN
Good idea. I was hoping someone would chime in, with. "yeah they feel about the same, your probably just under pitched."
CRJ
Hibernating
Toronto
i felt a big difference with my 11/17 in my ski. my SN hops right out of the water, im running a 762 61x/61x on 93
IS0LD0UT
I hate winter
MN
True. Wasn't sure how hard it was going to be to repitch. Pretty easy. 2 hookers is not a bad thing. :)
IS0LD0UT
I hate winter
MN
Turns out it was a fouled plug. What a rookie I am. :oops: The 12/17 does seem like an improvement from the 13/18. Now I need to try the stubby mag cone.
dfw
If you have an air leak or protrusion like grate bolts, it will vibrate wihile underway at mid to high power. A large hub that is too flat tends to struggle when the ski is first dropped in and not moving forward..
