- FL
How will sponsons help or damage my blaster 1 straight line stability in both smooth and surf. The ski is a rocket, full modded 1200 motor, and when flat out she likes to lean to 1 side. Kinda sketchy till you get used to it. My concern is the sponsons snatching when it "torq leans" and causing a high side problem. it corners pretty darn well now but i am told it can corner even better. Just want to avoid the mistake I made on my SJ with hull extensions and a long ride plate making it a bear to corner and catch/highside any little cross wake.
