'Spooge' is normal with any 2stroke. I think the brand of oil makes a difference. Cheaper oil = more spooge out of the exhaust.
WD40 removes the spooge off most surfaces.
WHAT RATIO ARE YOU MIXING YOUR FUEL AND OIL?/FONT]
So does a better brand of oil burn better? :dunno: Or since there is "spooge" does it mean the oil just passes trough the combustion chamber oiling needed parts and helping the rings make a better seal..
How much oil do you think it burns? compaired to how much just passes through ? "SMOOGE" "sorry flipper" "green peace" ect...
Seems to me oil acts as a coolant, sealer, and lubes
Does gas break down what the oil is in there for? So again more oil the better? :dunno:
If so let there be "spooge" run as much oil as long as it doesn't effect the performance..
Wow, now when you think about it. If this is true do stroker motors need more oil then stock stroked motors. Due to more travel of the rod and motor piston skirt and ring frction?
Will more oil help your rings seal better and make better combustion :crazy:??
"SPOOGE"is your friend.. well at least to keep your motor safe. stuff is a mess to clean up, wd does do well
