Standard hand pull or 2 inches off
I just wanted to ask around and see everyone's thoughts on stock length hand pool versus the minus 2 in hand pull what are the huge differences between the two or is there any huge difference I have a sxr 800 Kawasaki and I'm looking into getting a hand Pole and you can get either standard or two inches off what are the pros and cons if I get to inches off
Vumad
Super Hero, with a cape!
St. Pete, FL
If you go RRP or other similar design, you can always cut the tubes down, and if you go too short, just buy new tubes. The tube design costs more but gives your more options and would be cheaper than replacing a pole of the wrong length. Only you can decide what length is right for you.
Half flip95
Formerly pondracer95
short poles are for short people and short hulls.
you wouldn't need to cut the tubes. the tube design allows for a few inches of adjustment.
I used to run a rrp pole with std tubes at max adjustment on a lites sxr
