- Las Vegas
Yep. Got it started today. Removed the pump and pump shoe, did some of the grinding on the 650 pump, and even some of the grinding/reshaping done on the hull.
Tomorrow I'll get the pump mounting surface level. More grinding and some glassing.
Still need to order new bearings, send the bearing housing out for machining, order the zxi shaft (hopefully e-bay tonight, I lagged this week), and send my skat 16 degree off to Impros for repitching. Probably will get a bunch done and then be sitting on it for a week or so while I get the rest of the parts together. I can't ride for around a month anyways, hopefully I have it good to go when I get the OK to ride.
If you have all the parts already and have a little confidence I'm sure this mod can be done in 2-3 days.
