Super Jet starter quit?
im just getting a click from the ebox when I hit the button thought it was my battery cause it turned over slow a couple times but I just had the battery tested and its fully charged. what should I do now? I just got this back together after replacing the motor mounts im sick of working and ready to ride please help
also is it possible to remove/install the starter without removing the pipe.(factory b pipe) probably a really dumb question but im a noob and don't wanna do more work than needed
JetManiac
Stoked
Vendor Account
orlando
starter solenoid in ebox or a bad ground would be where I would have started.
Yep, pull spark plugs and turn over by spinning the coupler by hand first to rule out a locked up motor or pump or midshaft first. Then try starter directly from the ebox to bypass solenoid.
is it ok/a good idea to spray a bunch of w/d or liquid wrench on the bendix through the starter hole? it looks rusty from what I can see which isnt much of course. how do I try starter directly from ebox to bypass solenoid? im pretty ignorant/scared when it comes to electrical stuff. thanks all for the help
BruceSki
Formerly Motoman25
Long Island
If your bendix is visually rusty I highly suggest pulling the from cover and inspecting further. It's much cheaper to replace a bendix than grenaded electronics and cases because it went boom.
