Steering Cables, Throttle Cables, Cable installation parts
Steering Cables
Yamaha SuperJet and Aftermarket Standup hull cables
RN SJ 1996-2007 (or most aftermarket standup hulls and 08-20 SJ with a/m pole)
New OEM RN SJ steering cable $206. Sale 171.89
(We stock the beefier 06-07 cable, fits 96-07)
or
New RN Superjet 1996-2007 a/m steering cable $140. sale 123.89
SN SJ 1990-1995
New OEM SN 1990-1995 SuperJet Steering cable $204. sale 169.79
or
New SN Superjet 1990-1995 a/m steering cable $110. sale 103.90
RN SJ 2008-2020
New 2008-2020 RN SuperJet a/m steering cable 114.90
New FX-1 a/m steering cable $130. sale 119.90
(1994-1995 FX-1)
Blowsion HD steering cable 249.95 (includes HD SS no-slop rod ends)
(longer cable length is good for rickter builds or any hull/pole setup needing longer length in cable midsection)
http://www.x-h2o.com/threads/139787-Blowsion-HD-Steering-cable-179&highlight=Steering cable
Blowsion HD steering cable extension 11.95
WaveBlaster steering cables
New Waveblaster 1 (B1) a/m steering cable $159. sale 139.95
(1993-1996)
New Waveblaster 2 (B2) a/m steering cable $195. sale 179.95
(1996-1997) includes through hull fitting
ADA billet adapter bracket for B2 cable in a B1 $59.90
(bracket mounts to stock under hood location and is adjustable for the larger size and throw of the B2 cable)
Steering cable female socket end -OEM Yamaha 6mm for B2 cable (clean, used) $13.90
Steering cable installation kits
-For new builds (not usually needed for replacing an existing cable)
Steering cable installation kit -Mini JM kit 23.90
Parts to install in throughhull fitting- OEM clean, used parts (plastic cap, metal washer, plastic split washer, and rubber cone)
Steering cable installation kit -New OEM $58.99 sale 54.90
Throughhull fitting- OEM new parts (plastic cap, metal washer, plastic split washer, rubber cone, hull fitting)
**Add hull side fitting, rubber washer, and nut $9.95
Steering cable female socket end -OEM Yamaha 5mm SJ, B1(clean, used) $14.90
Steering cable male ball end with new stainless nylock nut -OEM Yamaha (clean, used) $14.90
RRP steering cable strengthening lock nut 8.95
(Replaces stock lock nut with much longer nut to support cable)
Super Jet 1996-2020 OEM SS Steering cable upper pole mount(U shaped) $10.90
Steering cable angle couch cable mount for custom setups $12.90
Cable extensions
Steering or trim cable extension 20mm/0.75" -stainless male to female 5mm threads 10.95
2 pack 8.95/ea
Steering or trim cable extension 30mm/1.2" -stainless male to female 5mm threads 10.95
2 pack 8.95/ea
*extensions fit std. SJ and B1 steering and trim cables
SuperJet 08-up pole side steering cable mount relo kit 54.89
(stainless bracket, ss hardware and mount kit for installing '96-07 longer throw SJ cable in '08-20 SJ or 94-94 FX1)
Steering cable mount for pole -billet, universal mount 39.90
RRP steering cable to pole billet mount kit 39.90
'No slop' SS ball joint heim cable ends $19.95/ea.
Std. 5mm Size for SJ or Blaster
Larger 6mm Size for B2 cables
Throttle Cables
Yamaha OEM Size Throttle Cables
Yamaha RN SuperJet OEM throttle cable $162. Sale 139.95
or
Yamaha RN Superjet length stock size a/m replacement throttle cable $99. sale 67.89
(1996-2020) (84 inches)
Yamaha RN Superjet (+3 inches) stock size a/m replacement throttle cable $85. sale 79.89
(87 inches)
Yamaha SN Superjet stock size a/m replacement throttle cable $79. sale 54.89
(1990-1995) (95.5 inches long)
-This longer sized cable is also often used on any superjet or a/m hull build requiring longer cable length for a/m carb setups.
Or
Yamaha OEM long throttle cable 122.99 sale 113.90
Yamaha shorty flatwater ski 74" length stock size a/m replacement throttle cable 55.95
Yamaha FX-1 stock size a/m replacement throttle cable $79. sale 55.89
(1994-1995)
Yamaha Waveblaster B1 stock size a/m replacement throttle cable $85. sale 55.89
(1993-1996)
Throttle cable to throttle lever adapters:
Most a/m throttle levers to Yamaha 6mm cable 11.95
BB Throttle Cables
MANIAC Big Bore Throttle Cable 35.95
Big and beefy!
Are you sick and tired of constantly breaking, kinking, hard to pull Yami sized and priced throttle cables?
These cables are 'large and in charge.' Super sized outer jacket with same sized center cable equals easy to pull. Butter smooth throttle control!
MANIAC cables are Kawi sized so no more need for a 'Yami adapter' for your a/m finger throttle. Your carb mounting bracket will require enlarging the slot or hole to fit this big snake of a cable, but you will get a laugh tightening your new cable ends with a 14mm wrench instead of a 10mm size.
Cable has a larger throw which will require moving your throttle bracket downward or use of a carb throttle wheel. If you have a standard RN superjet dual 38 setup, all you need to do is move the throttle bracket that is bolted on the top of the intake manifold. Reattach the bracket on the bottom of the intake manifold after enlarging the cable slot and you are go to go.
Now includes a custom brass jam nut at throttle end for easier adjustment.
Quality Stainless Steel ends and construction. 1 year MANIAC warranty-covers center pull cable breakage.
Available in 2 sizes:
RN length 82.5" from end to bend
or
'almost SN' length 90.5" from end to bend
MANIAC Big Bore Throttle Cable $35.95
ADA Billet Carb Throttle Wheels
ADA Billet Throttle Wheels 24.95
In red, black, blue, green, orange, or silver.
Throttle cable to carb mounts
Carb throttle cable mount bracket (fuel pump side) 23.95
Carb throttle cable mount bracket (diaphragm side) 34.95
Steering, throttles, grips, parts click here:
http://www.x-h2o.com/index.php?thre...le-grips-shop-ada-rrp-cold-fusion-odi.125011/
Kawasaki Steering and Throttle cables
Kawasaki Steering Cables
Kawi 1500SXR 2017-2024 OEM steering cable $126.24
Kawi 1500SXR 2017-2024 a/m steering cable $120. sale 102.
Kawi 800SXR 2003-2011 OEM steering cable $112.39
Kawi 800SXR 2003-2011 a/m Steering cable 66.
Kawi 750 SXi/SXi Pro 1998-2002 Steering cable 66.
Kawi 750 SX 1992-1995 Steering cable 66.
Kawi 650 SX 1991-1993 Steering cable 70.95
Kawi 650 X2 1991-1995 Steering cable 92.
Kawi 650 X2 1986-1987 Steering cable 92.
Kawasaki 650 SC (super chicken) a/m steering cable 56.95
Kawasaki 300, 400, 440, JS550, 550SX a/m steering cable 104.95
Kawasaki Throttle Cables
Kawi 800 SX-R (2003-2007) throttle cable 31.90
Kawi 750 SXi/SXi Pro (1998-2002) throttle cable 31.90
Kawi 750 SX (1992-1995) throttle cable 31.90
Kawi 650 SX (1991-1993) throttle cable 31.90
Kawi 650 X2 (1991-1995) throttle cable 31.90
Kawi 650 X2 1986-1987 throttle cable 49.
Kawasaki 650 SC (91-95 super chicken) throttle cable 49.95
Kawi 550 SX (1991-1995) throttle cable 39.80
Other models just ask.
Throttle Levers
UMI billet throttle lever 84.90
Black or silver, straight or angled
PJS Billet Throttle lever 75.90
TBM Billet throttle lever bushing $98.90
TBM Billet throttle lever bearing 109.90
HSI throttle lever (similiar to tbm lever)
Thrust finger billet throttle lever 84.95
RRP throttle lever 84.89
OEM Yamaha throttle levers -clean, used 29.80
Cast aluminum throttle lever 34.89
Most a/m throttle levers to Yamaha 6mm cable 11.90
Most a/m throttle levers to Kawi late model 8mm 14.90
Steering Cables
or
SN SJ 1990-1995
or
RN SJ 2008-2020
(1994-1995 FX-1)
(1993-1996)
Cable extensions
2 pack 8.95/ea
2 pack 8.95/ea
Throttle Cables
or
(87 inches)
Or
(1994-1995)
(1993-1996)
BB Throttle Cables
Big and beefy!
or
Throttle Levers
