Steering not right
Got umi pole and steering. Stock pump and nozzle. Stock steer cable. Ski turns slightly right. My weight on ski is even between feet. To go perfect straight i have to turn bars slightly left. I cut down the stock cable and it has improved but cant cut more off. I check nozzle is straight and bars straight with ski dry on trailer and there is maybe 3 to 4mm of movement in nozzle with bars straight and not moving. I have check all cable holders and cable aint moving. I tried disconnecting steering cable and just using the pump water for steering the nozzle and it still tracking slightly right with steering bars detached. Is not speed related happens slow or wot.
mike b
California
Do you have a stock cable? Blue or red? Blue is typically a 3in throw and red is 4in throw. Make sure that is proper first. I've used a 3in in a pinch and was a pain to ride. Only turned one way for the most part. Post up some pictures of pump end and pole end
