cookerq62
Life's Been Good
- Upper Bucks, PA
For one of my classes we had to build part of a go-kart frame. The material we chose was carbon fiber. So I went ahead & ordered some 5.7 oz plain weave carbon from us composites & used some left over resin from one of my builds to lay it up. When we were done I had some left over so I made some samples to put in our test machine. I threw some scrap strips on wax paper & let them cure for about 20 hours & then stuck 'em in the test machine. Over all I broke 16 samples that had an average break strength of 44,000psi. The samples were all over the map from 30,000 psi to 73,000 psi. I expected that because the samples looked like a monkey layed them up. The really cool thing about the carbon is it doesn't behave like a metal at all. There is zero plastic deformation right up to when it breaks giving it working strength better than mild steel. So basically if any reinforcements you do or parts you build using the resin & carbon USComposites sells are going to be stronger than mild steel no matter how bad of a job you did. All of the pieces broke as a result the crimp in the fabric. Crimp is essentially an internal shear that results in the fabric due to it's weave. The effects of this are less pronounced in twill fabrics and nearly non existent in stitched & unidirectional fabrics. So those fabrics will be stronger. I attached a pic of one one of our samples under an electron microscope after it broke. You can easily make out the carbon & the epoxy. I hope some one else finds this stuff as interesting as I did.
