LIVE2RIDE Powersports
Live & Die 2 Ride
- WorldWide
What is stock timing on a 61x? Thanks
Its 15-degrees at 1200 rpm and 21-degrees at 5500 rpm with the stock CDI.
Here are the dial indicator specifications for the stock 68mm stroke crank in case you would like to mark your coupler or flywheel.
TDC = 0.0000
05-Degrees = 0.0045"
10-Degrees = 0.026"
15-Degrees = 0.059"
20-Degrees = 0.106"
25-Degrees = 0.164"
30-Degrees = 0.230"
35-Degrees = 0.306"
40-Degrees = 0.391"
