Super Jet stock bilge hose fittings hull to reduction nozzle?
Stock hose from the hull fitting to the reduction nozzle fitting was in horrible condition. I went to change it and realized it was two different size fittings. The one on the reduction nozzle was much larger than the metal tube coming out of the hull. I have it clamped on there, looks like it may be fine, but what other options are there? Ordering a stock one from yamaha?
btmboards
Brett
Oceanside, Ca
Wierd, pretty sure mine are the same size. If they are, go get some rubber fuel or coolant line from auto zone and it should stretch enough to go on the big one then clamp it
yeah its actually a pretty big difference on mine. Ill take a picture this weekend. Probably try to get some hose that fits closely on both of them then use clamps
On every ski I have owned the reduction nozzle is the regular 3/8" and the through hull tube is the larger one with a molded hose that changes size to connect them.
Sent from my ICS E3D
