So I've pulled apart my stock intake setup, and noticed that there's a spacer between the carbs and the intake. Do I need a total of 4 carb gaskets to get this thing bolted back together?
Kawi uses the coated metal gaskets. If the coating is still good you can re-use them. If damages, gently scrap off, then go buy some Copper Ultra Coat by Permatex, I think that is the name. It is like a copper spray paint. Paint both sides and let dry. Then use them. I pulled my carbs on my SXR 20 times I bet, I only replaced gaskets one time I think.
Yes, you will need a total of 4 gaskets when changing the carbs. I have reused mine for multiple carb removals. Gasket is not needed on the FA for the junction is above the carb inlet.
