Super Jet stock exhaust question
Fstrkls1
Fast and Reckless
Manteca ca
Yes sir it should bolt right up. The ports on the 701 mani are bigger than the 650. You might even notice a lil more brap out of it with running the 701 mani
AlexQuesnelle
TotoMotoBoatosaki
if you put a 650 coffmans pipe on a 61x would that cause it to overheat, i noticed when i swaped out my 650, that the mani water jacket didnt line up 100%, ive come close to melting a pipe coupler. the pipe is getting extremely hot, any ideas?
Fstrkls1
Fast and Reckless
Manteca ca
The 650 mani has smaller exhaust and water ports the the 701 you should check how much smaller cause that could end up frying your motor from it over heating. If the
