the siphon bilge never fails aslong as your moving and clears more water than you think, the hood also lets in far more than you think so run both. one is good so two is better
the siphon bilge on my ski and my brother in-laws ski, BOTH failed within a couple weeks of eachother, would do 5 laps around the lake and little to no water would suck out. Best solution, (for me) rip siphon out and i am running a 500 gph bilge, going to put in a 800gph bilge this winter possibly as well.
you did the toggle switch over the twist switch right??? i dont think i would like the twist switch... yeah it seems like his setup's are pretty legit.second the OCD switch...bulletproof
I will look into that bar mount switch, i am tired of bending down to turn on my switch... and i diddnt block off the line, i just ripped out all of the hose, haha... i am putting on a solas pump here in a couple days so i am going to blow some air through just to make sure it is not clogged, and will be using it as a second cooling line...
btw, my single 500gpm pump does pretty good, i have a stock hood aka Water catcher... and that little guy does pretty good for me,,, i love to submarine too, he doesnt get much of a break but i will probably be getting a 800 gpm pump to help out, thinking about doing the scupper valve too...
I would recommend to " ramp " your scupper tube its sitting way high.....
