Hello all, I have a 96 superjet all stock with stock bilge and a rule 500 electric bilge, took it out recently and it kept having to drain water every 15 seconds for a few seconds then stop and keep doing that over and over, so today I took it to the boat ramp to see what it was and I ran it in the water while on the trailer to find that it was the stock bilge letting the water in, this ski didn’t have the stock bilge when I bought it so I added it back in, I did everything, it is connected to the proper fitting on the pump nozzle, the one that stock out into the middle so water goes by and then creates vacuum to suck it out I added the little 90 deg fitting that has the small pinhole for air when floating and it has the loop to the top of the engine bay but instead when I ran it I saw it bubbling from the bilge box and the water level rising so I disconnected the line that does the loop up to the 90 deg fitting to see that the line was slowly pushing water INTO the engine compartment and when I gave it more gas it pushed even more water, anyone know why this would be? It’s definitely hooked up properly but somehow is pushing water back into the engine bay, so I put my thumb over the line to stop the water flow and it did then I throttle it a little and it stayed at bay and wasn’t flowing out and water level was not rising in the engine bay after that, so it is definitely the bilge but what would cause this? Right now I’m thinking I’m just going to delete the stock bilge as my best answer given that I have the electric one running while I ride anyway, but just looking for an answer and what you guys think my best solution is... thanks all!
