Hello
I have made a few threads about this before around the place but after 6-8 months I still have not found a solution to my problem, Basicly when the ski is running and you want to turn it off hitting the stop button doesnt do anything and the same if you pull the lanyard, I have had this problem on and off for ages and just cant figure it out, I have replaced the start stop switch, the coil with a jss/jetmaniac one, the cdi to an epic, changed the plugs from the start stop switch and tested all of the wires with a multimeter but still cant find anything....
One of the guys on the aussie forums suggested checking the stator for a good ground but I have almost no resitance between the ebox and the motor and you would thing it wouldent run with a bad earth, Has anyone had this problem before or have any other suggestions? If I cant get this sorted soon I may just have to buy another ebox.....
Thanks for reading
MASSEY
Thanks for reading
MASSEY
