Not all 5mm cranks will clear cases, only 5mm stroker cranks with stock OEM rods from Yamaha will just about clear most of the time, a few times the casting in the crankcase does hit in a couple of spots. All 5mm and rebuilt cranks using HOT RODS will not clear the cases and will need about .040-.045 to clear the bigger big end of the HOT RODS as they are beefier rods.
Not true about stroker cranks being run wot for extended time.
8mm strokers must use 133mm or 134mm length rods as it won't work with 125mm stock length rods.
Wide open throttle running is built into the engine build spec's itself and is Never a problem by itself. (port mapping for target rpms, compression ratios, squish design, ignition timing, and overall carb efficiency)
I do believe that the 5mm cranks that do use stock OEM rods MAY suffer a little more wear over time, I still get 3 years or more beating them to death here in Florida with our extended riding seasons and salt water to boot. (more care must be taken in salt water riding)
Proper case preparation is always needed for any modified engines including strokers and type of running use.
And Yes, I do believe one can have too much power, look at me with my low level ride skill with my VERY high skill at making lots of HP. I most of the time cannot ride/tune what I can build!
As these 992/1014 1000cc monsters are way too much for most riders, and definitely includes me!
Engine setups must also follow cc rules if competing in certain classes and fit customer $$ buget.
By far it's best to build a 8mm stroker/long rod/small bore/Lamey PV cylinder engine over a big bore/stock stroke/lamey or stock cylinder engine.
