For all you owners out there,l thought this would be great to come together and share our builds with the Stunt Hull.Gen 1,2,and now 3!
This will be great to see how you guys built yours or changed different things to better suit your own personal way you ride.Also,how you improved different areas.
SO far,l am experiencing some alignment issues with the pump.Always start here because it will determine how everything else lines up.
Spent Saturday in the shop finishing the alignment of the pump.As you can see from a couple of the pictures,l had to grind down alot of the glass near the pump seal.lt's paper thin at this point.Should get my fiberglass from US Composites today.l really appreciate the poor guy that helped me.Had him on the phone for at least 30 min ordering!
l bought the 12 oz biaxial cloth to build this and some other areas up.One question is how much should l build up the pump area?? Two layers or more? At least,l will just need a couple of shims to make a good seal.Chad has told me repeatedly how important this area will be to get perfect(thanks,man).
Also cut the hole thru for the driveshaft.The pump and driveshaft have been split since l got them,so need to get the shaft pressed on this week.
