- smiths falls
What function does a pump and pump cone serve??????
without a pump, an impeller is just a propeller.
the pump cone allows you to tune the flow through the pump and the corresponding pressure in the pump. Short cone = High flow, low pressure = quick acceleration. Longer cone = Less flow but at higher pressure = top end speed.
Your ski should have a vacuum-driven siphon bilge from the factory. Look at the back of your ski and find the steering nozzle. Hint: it turns when you turn the bars. That steering nozzle has two bolts (one top, one bottom) holding it to the reduction nozzle. The single hose mounted on the reduction nozzle sucks water from the engine bay since a vacuum is created as high speed water is shooting through your reduction nozzle. If that is there and connected, chances are you have the little white plastic box in the engine bay that sucks up the water too...and that is the complete siphon bilge system. White plastic box is clipped down to the engine bay floor under the intermediate shaft housing (which is mounted to the bulkhead behind the motor).
If you look at the next piece of the pump toward the front of the ski, that is the stator section. (Not to be confused with the electrical stator). You will also find a hose connected to the side of the stator. Since this is in the stator section, and due to the location / geometry of that hose connection, water is forced through that hose and up through your engine / exhaust for cooling. Opposite action of the siphon bilge, basically.
