SuperFreak Badass 155 Pump Fitment
Looking to get a clear answer on the fitment of a 155mm pump into a 2015 Carbon SuperFreak Badass -7.
Will a 155 setback mag (Torrent, Skat, Maxx, etc) Fit without having to do any glass work. I know the pump shoe will have to be swapped out for a 155, and my 144 trim will no longer work, but just want to know what I am getting into.
@Marcgraham27
Jr.
Standing Tall
Staff member
Hot-Lanta
Would not work in my old -4.3 badass. Besides the actual fit, Tem recomended not going above a 148, as the inlet tunnel would not supply water efficently enough.
Well this is awkward lol.
McDog
Other Administrator
Staff member
South Florida
It's not set up for 155. The ones that are have a negative space on each side of the pump. But even if you could sandwich it in there, the main issue is that the intake tunnel isn't big enough to properly feed the pump. At least that is what Tem always told me.
I've noticed before on my -4.3 that the pump shoe area is pronounced/ prominent compared to a superjet so that if you were to drive it up on the shore (beach it ) it would be more susceptible to damage.
