Superfreak Circus 2013, full carbon, flatwater, easy backflip machine!
This used to be Chris Anyzeski hull from 2013. Ski is originally built by Tem at Superfreak.
Posting for a friend – he has owned it sine 2015 where we imported it from Australia Sea World jet ski show. Ski is located in Denmark, Europe, and has been used around 20h since purchase.
When we bought the ski, most of its running gear was new/reconditioned – so not many hours on this engine setup.
Info:
1000cc x-scream, 89mm 1st bore, 10mm stroke, Crank works crank.
Boysen inlet with reeds.
RRP carbon wet pipe with flow valve.
MSD total loss w. MSD flywheel in RRP billet casing. All wiring has been renewed and is in great shape. Electronic switch on the outside of the lexan cover for killing the spark.
Carbs are DASA 49mm
Flywheel cover is DASA with o-ring.
Jazz 9L fuelcell.
14 vein, 155 setback Skat Track pump, with thrust trim. The complete pump with prop is the same as used on Chris Anyzeskis WF 900 ski, and is a perfect match for the 1000cc XS.
RRP steering setup with RRP lightweight pole and chinpad.
Build parts like Bendix, starter, start/stop switch etc. are all OEM.
The ski is in great working order, and turf is in great condition.
Tote like shown in the pictures can be purchased with the ski but needs to be assembled.
Many spare parts can be included with the sale.
Shipping can be arranged.
Price 15.500 US
