Superjet 701 Prop recommendation
UAE
Hello guys, thank you for the amazing forum which I have learned many things so far. Im wondering if a prop (impeller) investment will put any improvement on performance or handling for my Superjet, running oem prop at the moment along with 144 mag pump, MSD enhancer, ada head, B pipe, v force 2 reeds and oem carbs. any thoughts about a good prop for free ride and what is your recommendation on props or should I keep it as it is. thanks in advance
Roseand
The Weaponizer
Wisconsin
I'm assuming you're running an 08+ SJ prop?
It may be the ticket depending on how close to the vanes you can get it. Not sure how tight to the vanes it sits since it's meant for a stock size hub.
Roseand
The Weaponizer
Wisconsin
I can't speak for an oem prop on mag pump, but I prefer skat swirls on mag pumps. Very smooth acceleration and they don't run out on top. Not to mention skat swirls are what all of us run on our 155s,both on oem and mag pumps. They work awesome.
Sarasota
I have a Hooker 10/16 with pretty much the same setup and it licoriceing rips midrange. Everyone that rides it loves it and says it's an arm ripper for a 701
bored&stroked
Urban redneck
AZ
I have a skat in mine, its ok.
There's a hooker 10-16 in my other superjet with a similar setup and it rips, I wanna try a hooker in my ski as well.
