Super Jet Superjet 760 RR vs 2008+ Superjet 700
Best baseline for freeride/freestyle?...
2006 Superjet 760 RR vs 2008+ Superjet 700 (stock)
The 2006 Superjet 760 RR comes from factory with:
http://www.x-h2o.com/threads/8176-New-Superjet-Unveiled!
PROTEC Mach 1 Exhaust
44mm dual carbs (i think so...)
PROK Multi-Fit Flame Arrestor
Mikuni Dual PRIMER Kit
SOLAS Impeler
WORX Intake Grate
Rius Racing Front Sponsons
Rius Racing Carbon Fiber Rear Hull Extensions
Oddi Custom Grips
UMI Throttle Lever
Handle Pole HD Springs
RULE Bilge Pump
RIUS RACING Mats
RIUS RACING Graphics
Rius Racing Metal Fuel Cap
Rius Racing Chin Pad
These jetskis, in used condition, cost about the same $.
What's your favorite base line for a freeride/freestyle jetski, the 2006 hull with better engine components or the 2008 hull but fuly stock 700cc.
Price of the final build for a freeride/freestyle superjet does matter...
What do you guys think?
The Rius Edition is more oriented towards racing. The 760 topend has the higher sitdown port timing and is not conducive to bottom end power. The sponsons and hull extensions are race mods.
The other parts on it sound very nice.
I'd be leaning towards this ski if it were me. But I'd be prepared to remove the racing mods and send the motor out for freestyle/freeride porting.
Some people prefer the 2008+ hull for freeride and some don't. Almost nobody recommends it for flatwater freestyle.
Do you know where can the engine be ported for freeride/freestyle here in Europe?
Is it hard or/and expensive to change from a 701cc to a 760cc engine? What are the differences between the original 760 engine and one 701 converted in a 760?
Which is best for freeride/freestyle, a 701cc or a 760cc? (both stock or compression head, lightweight flywheel, etc...)
Which carb or carbs are the best for the 701 or the 760 engine?
That Protec pipe maybe need also a change... Best pipe, Factory B Pipe or Factory Dry Pipe?
Race sponsons also to remove... Best sponsons, tubbies III or tubbies destroyers?
Both hulls need reinforcement?
