- Brentwood CA
Just installed a 61x into my SN, and am having issues with the new electrical...
I purchased a 61x ebox to replace my old rusted out ebox that I previously had with the 650. Installed the 61x motor and ebox, but the motor didn't crank. I ohm'd out the start/stop switch, and it seems to be functioning correctly. I then jumped the starter relay and the starter turned, so I assumed the relay was the problem. Installed a new starter relay, and still have the same problem! When taking the small brown wire off of the starter relay and touching it to the larger red battery wire it does spin the starter...
Another confusing part- when jumping the small brown wire and the small red wire on the ebox end of the connector that goes to the start/stop, the starter does not spin... which I thought it should because you are completing the circuit?
Any info that anyone can give would be appreciated!
