- Lake Lotawana, MO
I went riding over the weekend and the ski had been running good however the last time I rode I noticed the pisser sputtered as I was idling out of the cove. And when I'm running outside the no wake buoys it's not a steady flow like normal. I'm running a bpipe with one pisser, single line. The line from the bottom of the pipe runs to the head, top of the pipe runs to a T into the stinger. After the T is a flow control valve. Should this be set up differently?
Also, as I left my cove yesterday the ski seemed fine at idling speed and I hit a wave or two then it wouldn't go above an idling speed but felt a lot of vibration under my feet. I had this happen on a SN before but it wouldn't move anywhere because the driveshaft was worn. Does this sound like the same situation just not as worn down? Ski runs fine at idling, just when I give it throttle it doesn't go anywhere.
I know best thing is to remove it and take it apart and check it all out but it's on my dock and the ramp is on the other side of the lake. I'm just looking for feedback/things to check on the dock before I tow it to the ramp. Thanks guys
