I picked it up from the shop today, I had a stock head put on. It's a 760 engine, but I really don't know to much about it, I am learning as I go. It has aftermarket air filters, and pipe. The shop said the carbs are good and don't need a rebuild. Today was a rainy day, but I went out for a ride. It started up no problem and ran strong, until I released the throttle. When I would stab the throttle wide open, it would not rev past a certain rpm, and it wouldn't accelerate. If I left the throttle half way open for 2-5 minutes, it would finally accelerate again and run strong, until I let off the throttle again, and the same thing would happen. I checked the plugs, they had a brownish color. My mechanics said, since it has an aftermarket pipe and air filters, the rainy day and cold weather was most likely causing the problem. What do you dudes think ? Edit: after reviewing the mukuni site, it says meteorological conditions most certainly affect the carbs.
