Vumad
Super Hero, with a cape!
- St. Pete, FL
I just picked up a B1. I plan to put my Sj back to stock with the B1 motor to sell it. I have a lot invested in my SJ including a brand new B-pipe, freshly rebuilt motor, etc I want to put in the B1.
I plan to swap everything, so where will this be an issue? I know the midshaft is a different length. Will this have to be pressed or can I do it myself? (I have a brand new WSM housing). I want to run my motor as is, so how do I connect my B-mod to a TDR waterbox. My pump is also in excellent condition and tapped for dual cooling, are the drive shafts the same or do I need to swap something?
It's a stock B1, just has a TDR waterbox, ride plate, etc. My Superjet has almost everything available, and mechanically everything is new or like new.
Thanks.
Note, I want to keep my superjet chamber, as I might build a surf hull (standup) that I can swap my motor into for Daytona, etc, or get a Rhass kit and occasionally run it in a X2. I may end up with 2 or 3 hulls, and one motor to maintain.
Thanks.
