A recent rebuilt of the top end and carb's of my superjet.
I've had many problems settings up with the carbs originally running 1.5m (55psi) going to a 2m needle and seat also running pop-off of 18psi (Shinny Silver springs) this seems to of been the best set up but still needs a little more adjustment.
I now seem to have another problem which I didnt have before the rebuild, it runs perfect for a whilst but then it will feel like its missing (badly). If you then leave it for a whilst its fine then do the same thing. It doesnt feel like the temp sender cutting in as that always completely cuts your revs ?
Could I have an air leak from the base gasket ?
Any ideas ?
Running on ski - Factory B Pipe, Carbon Tech Reeds, Carb Spacer, RAD lightened fly wheel, msd Enhancer.
Any ideas ?
