Super Jet Superjet wont turn over, possibly start switch
I hit the start button on my superjet and nothing happens. I took the electrical box apart and touched metal on the solenoid and it turns over. I took apart the start, stop, and tether switches and they all look fine. If anyone has any input that could help it would be greatly appreciated.
Thanks!
Connect two small wires from your battery +\- to the tiny posts on the solenoid, if it turns over you problem is wiring 'to' the solenoid. If it doesn't turn over your solenoid is toast.
Jim
'kotajoe
Do Good Crew!!!!!!
NRH, TX
Clean the plugs where the s/s switch connects to the ebox wiring, clean the contact points in the s/s switch, put dielectric grease on all the contact points
im having a similar problem i hit the start button nothing no click nothing i replaced the solenoid and s/s/s from my blaster and still nothing i can jump the solenoid across the post and it turns over its a new build motor brand new starter is good ground is good please help me too
SkiDiggity
formerly kawirider142
if you take apart the start/stop switch on the inside there are these brass contacts that get a black coating on them. clean them with a wire brush throw it back together :). Also disconnect the black and white connector and try it. If it fires up that way then it is the switch for sure
Quinc
Buy a Superjet
California
Twice now I have had a similar issue where I hit the start button and nothing happens after the battery has been on the charger. Try disconnecting and reconnecting your battery.
QuickMick
API 1104 AWS CWI
Jim
are you saying to bring up a hot and a ground wire from the battery and touch each of them to the posts on the solenoid?? Not a good idea. Disconnect the Black / White wire from your Start/Stop switch and hit the button see what happens. Also make sure your battery is up to snuff.
