SX-R Wet Pipe ???
D Slicker
Durham, dont forget it
Pottstown, PA
I just finished installing my pipe and am not sure what to do with the sensor that was in my stock pipe? Can I just remove it or do I need to jump the termminals:rolleyes:
GIL
Power In The Hands Of Few
Cullman AL
Leave the sensor that was in stk pipe unlugged-sensor goes in yer junk pile now. Do not jump those terminals. If you have '05-take the green jumper that came w/yer pipe and plug it in where yer ambient air temp sensor is and add that sensor to yer junk pile. Go to 'Freestyle section' and read post'freestlye sxr-opinions'. I have pics there-in the one of engine I think u can see the 'green jumper plug' and where it goes. If u go to water and feel like yer set up is weak-let me now-I've got a setup that I am real happy with in Alabama-ie-close to sea level.
D Slicker
Pottstown, PA
Thank you both, I jumped the air sensor last season. The exhust sensor was the issue. I will be trying it out next weekend. I will let ya know how it runs. Did you use the jets that came with the pipe or the stock ones?
GIL
Cullman AL
Use the new jets!!!!!!!!!!!!!!!! Tooooo lean if u dont. If u have quick access-put 80gram pop off springs in carbs w/u rejet. Thats wut I'm runnin.
D Slicker
Pottstown, PA
Thanks for the info. looks like im pullin carbs this weekend. I swear I will never be done with this thing...:banghead:
