Sxi pro conversion coupler alignment
In the process of taking everything from my 92 750sx and putting it in a 98 sxi pro hull. Having some major alignment issues with my shaft and engine coupler. The shaft pitches way up. Using the sx bulkhead bearing with the spacer that was on the sxi pro. Tried shimming the rear of the pump 1/8" and had no luck. Anyhelp would be greatIMG_0376.JPG
VXSXH20
Sionis Industries
Mid-Atlantic
A sxipro hull uses a different and longer driveshaft. The Motor placement is about 2" further forward than a pre1998 sx or sxi Hull.
I've got the right length by using a 550 coupler on my SX shaft. The problem I'm having is the shafts don't align up and down. The pic is of my engine pulled forward still sitting on the mounts
