Want to Buy SXI Pro or SXR START/STOP SWITCH (Lanyard style only)
jeckert
Going backwards
Chicago
Hi looking for the Kawasiki SXI Pro or SXR 800 "start/stop switch" (looking for the lanyard style kill switch)...hoping to find one new or in great condition. Mine works, but intermittently shorts out.
Thanks in advance!
You can disassemble the switch housing with the 4 phillips screws on the underside, and the buttons will twist apart. Careful to keep track of the interior bits and their orientations... The contacts on the buttons get a little crusty and so do the washers. A quick scuff and some dilectric grease and you should be good to go. It's also a good idea to separate the connectors and pop the pins out to do the same.
Protip: if you own a pool, a quick dip in muriatic acid, rinse/wipe and grease goes a LONG way. Learned it from an old head and I've been using that trick for years. Pins pop out easy with a little tab on the inside of the connector. A cheap pin-pusher off amazon is a solid investment too. $8 tool has saved my ass plenty
