SX/SXi/SXi Pro SXI pro takin on water during tricks, help!
ohio
I have a 1998 SXI pro with a carbon fiber R-pot hood. when ever we do tricks where the ski goes under water it drowns the motor right out. Is there a way to keep water out long enough to get above water again with out killing the motor? Does it do this with the stock hood?
Thanks, Guys!
Chris
JetPilot1970
Work at Sea-Doo Factory !
Quebec, Canada
Usually a "race hood" let more air goes inside, so the water too. With stock hood, I have water in the engine compartment too but not as much as you. My engine never stops. You should protect your engine from water because you don't want to bend a connecting rod since water doesn't compress like air. If you have full flow air intake it may be possible to put cover on it espacially designed to stop the water.
