SX/SXi/SXi Pro SXI wont keep running.
n247hp
N247hp
Philly
checked all the fuel lines and replaced them. The ski starts with choke closed or starting fluid and then idles, followed by a rev up and dies. I guess it revs up cause it leans out cause it runs out of gas. do you think its the carb diaphragm not pulling gas in or something else. The pulse line is connected and is there any way to test that???? Any suggestions will be appreciated. thank you
