- Akron, Ohio
Selling my SXR1100 professionally built by Speedlab Performance in Florida in 2020. For those who don't know, this is an SXR800 hull which was stripped down, painted & refinished with an 1100cc motor from a sitdown jetski. This thing is extremely fast without sacrificing reliability all while being much lighter and more nimble then a modern 4 stroke stand up. The craftsman ship on this ski is second to none. The hull was painted both inside and out as well as the cases. It is set up to run on pump gas, has aftermarket pump to put down the power with a downward facing trim system as well as some hull modifications and RRP hand pole to make it handle even better. This ski maybe has 2 hours on it since a fresh rebuild. It has always had ethanol free gas run through it with Amsoil Dominator. It fires right up and runs flawlessly. Please message me with further questions on the build. If you see this add, it is still available. Clean title in hand.
Asking $9K & Located in Akron, Ohio. Will consider delivery for the right price.
